Clutch pedal vibration
84,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
DEMONDEVILJAMES123
Zafira diesel 1.9 cdti problem with clutch vibration.. car drives fine, no problems at all however when I start the car there is vibration in clutch pedal.. press in clutch pedal 1/2 way (sort of bite point) there is like a loud hum noise in engine. pedal to floor no noise just slight vibration on pedal. release clutch pedal and on bite point again same hum noise and vibration.. gears work fine, plenty of brake/clutch fluid in reservoir and no obvious leaks around. I was thinking release bearing? could this be? thanks.
Jul 26, 2019 at 4:47 PM
  • 110,245 POSTS
Welcome to 2CarPros.
Chances are you are correct. If the release bearing is going bad, it can cause both of the symptoms you described. If I had the specifics directions for this vehicle, I would provide them. However, this model isn't offered in the US and my manuals don't provide technical information on it.
Let me know if you have other questions or need anything.
Jul 27, 2019 at 12:35 PM
