Clutch pedal
1986 CHEVROLET S-10
173,000 MILES • 2WD
DEBBIES1986CHEVYS10
Hi, my vehicle got stuck in reverse. I had to turn truck off to disengage then while in first gear with clutch in I tried starting it and the truck moved as if the clutch was not in. I have no leaks anywhere and have bled everything every way possible. The clutch pedal goes all the way to floor and comes back up but it feels like it is not hooked up it feels like it is not engaging at all, no pressure.
What else can i do to find the problem?
Dec 4, 2017 at 6:06 AM
  • 31,937 POSTS
If you have positive pedal pressure the hydraulics should be fine, this will probably be a mechanical problem with the clutch. you may have a failed pressure plate or clutch plate. it sounds as if the only option is to remove the transmission and inspect for damage in the clutch.
Dec 4, 2017 at 6:31 AM
