clutch or gear oil
100,000 MILES • 2WD • MANUAL
T.J. WILSEY
i was driving on the highway when in fifth gear i started to lose speed i had the gas pedal down and still was losing speed. i was able to change gears but it didn't do anything. i don't know much about cars so sorry if this doesn't make sense. ask me question i will answer to the best of my ability.
Dec 28, 2019 at 3:03 AM
Good evening,
Does the engine rev up when you push the gas?
It sounds like you have a clutch that is slipping.
Do you have a hard time putting it in gear from a stop?
Dec 28, 2019 at 9:08 AM
T.J. WILSEY
i push in the clutch and it starts just fine it will go between gears with no issue but when I go to release the clutch nothing the car stays running but won't move if I press the gas it revs up it started on the highway I was in fifth and I started to lose speed I made it home a good 35 miles after issue started, but it wasn't the easiest thing to do. I had to switch gears with gas down and could not come to a complete stop it was basically over.the car been sitting since. I have had people look at it and nobody for sure gives me an answer, but some say clutch others say clutch master cylinder. somebody else says I probably just need gear oil. I'm not the best when it comes to cars. I'm learning as I go. all the help will be greatly appreciated.
Dec 28, 2019 at 12:09 PM
The master uses brake fluid.
The trans-axle uses gear oil.
It does sound like your clutch is slipping.
Dec 28, 2019 at 6:51 PM
I found a video for you of the clutch replacement procedures.
https://www.youtube.com/watch?v=6N6b5F2ChyE
Dec 28, 2019 at 9:34 PM
T.J. WILSEY
I watched the video and first off I never knew that it took that much work to fix a car let alone only one part of a car. not only am I new in the world of fixing cars but I don't get all the tools I would need for this advanced work. I'm stuck in a jam because I just checked the gear oil good not low. master cylinder good. so what the clutch and I can't fix the clutch with what little knowledge I have. so shop they want way too much money. so what do I do junk this baby? I can't do that because some of the parts I got on there I got from my friend who passed away last month (RIP Bobby). so any ideas how to get this fixed without losing an arm and a leg?
Dec 29, 2019 at 3:07 AM
You can call and shop around. I would call local shops and see if they would help with pricing. Many local shops will be cheaper and they could finance the job as well for you.
Dec 29, 2019 at 3:23 AM
