Clutch not engaging
197,000 MILES • 2.8L • 6 CYL • 2WD • MANUAL
ERNIELEE
Replace clutch pressure plate, throw out bearing, pilot bearing, rear main seal and slave cylinder. Without car running you go through all the gears with it running you push it in the clutch put it in gear and it tries to engage but it won't. the car was sitting for almost 11 months. When i push clutch it disengages but won't fully engage it just sits there and jerks? Help
Aug 25, 2019 at 2:16 AM
Good afternoon.
when was the clutch replaced? Now or 11 months ago?
Aug 25, 2019 at 4:51 AM
ERNIELEE
11 months ago, but i am just about to put a new kit in it in a few minutes Sir.. Been working on it since about 3:00 pm yesterday.
Aug 25, 2019 at 7:04 PM
Okay, it sounds like the disc is stuck to the flywheel from sitting. When you get the transmission out, I believe you will find the disc stuck to the flywheel.
Aug 25, 2019 at 7:43 PM
