i have fluid to slave cylinder and it moves but dont engage the clutch to put it in gear
Apr 20, 2013 at 7:22 AM
✓Experienced Mechanic
Check that you have no air in the system, this can affect travel at the slave, re bleed and test, if this works, check slave and master for leaks, if not probably a worn clutch that is due for replacement.
