Clutch noise
1999 FORD RANGER
180,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
RENEE HESS
Clutch making loud slapping sound when engaged. Just started afraid to drive. It drives just fine goes into gear, smooth shifting. Engine is running fine.
Dec 4, 2017 at 2:26 AM
  • 31,937 POSTS
Only thing to do here is get the box out and inspect the clutch for a mechanical problem. i have never heard this type of noise, normally you get a whine or a rumble noise. it may be slipping badly and this will result in total loss of drive shortly. get this investigated ASAP before it fails and leaves you stranded.
Dec 4, 2017 at 6:23 AM
RENEE HESS
Thank you so much for your help. Will take your advice.
Dec 4, 2017 at 2:43 PM
  • 31,937 POSTS
Okay, please post back when you know what the problem is, as this may help other members in the future.
Dec 4, 2017 at 7:46 PM
