clutch may be slipping
130,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
NO7SEC2
clutch seems to slip in 3rd to 5th gear slightly.
Feb 10, 2022 at 6:22 AM
  • 110,251 POSTS
If the clutch is starting to fail, it will be most noticeable in fifth gear when the engine is under a heavy load. Try this. When driving in 5th, let off the throttle and then hit it hard to see if the engine rpms increase and the vehicle doesn't.
If that happens, the clutch needs to be replaced.
I attached the directions for the removal and replacement of the clutch assembly. Additionally, the removal includes what to check.
The transmission needs to be removed to replace the clutch assembly.
Feb 10, 2022 at 11:35 AM
