Clutch lock up
16,000 MILES • 2.4L • 4 CYL • TURBO • 2WD • MANUAL
ROBERT COLMAN
Hi, my truck was running perfectly until I came to a junction, and could not get any gears. The clutch pedal is good. will go into all gear when engine is off, but won't drive. Installed a new clutch about 4,000 miles ago. There is a little fluid on the bell housing. any ideas would be really helpful.
Jan 22, 2019 at 2:10 AM
  • 55,711 POSTS
It sounds like the clutch is not disengaging due to a clutch disc falling apart did you use a high quality clutch? Here are two videos one showing symptoms of a bad clutch and the other to show how the job is done on a different car but the process is the same.
https://youtu.be/EpBMj5ZY_bo
and
https://youtu.be/6N6b5F2ChyE
This guide can help as well
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Jan 23, 2019 at 4:21 AM
