There are only two to consider, the rubber hose between the master cylinder and the reservoir and then a steel line that runs between the clutch master cylinder and the slave on the transmission.
I attached a picture of the master cylinder and rubber reservoir hose. The steel line you should be able to follow.
Here are the directions for bleeding:
Bleed the clutch hydraulic system.
a. Attach a hose to the bleeder screw, and suspend the hose in a container of brake fluid.
b. Make sure there is an adequate supply of fluid at the clutch master cylinder, then slowly pump the clutch pedal until no more bubbles appear at the bleeder hose.
c. Refill the clutch master cylinder with fluid when done.
d. Always use Genuine Honda DOT 3 Brake Fluid. Using a non-Honda brake fluid can cause corrosion and decrease the life of the system.
Let me know if this helps or if you have other questions. Also, let me know where approximately it is leaking from.
Images (Click to enlarge)
Dec 28, 2018 at 2:51 PM
