Clutch/flywheel
100,000 MILES • 2.0L • 6 CYL • TURBO • 2WD • AUTOMATIC
SCOTT SUMMERFIELD
New member here and first time Audi owner! have maybe a big issue that I need some help with if someone could oblige.
When in neutral I get a strange noise at the bite point with the clutch, change in engine sound if you get me.
Fine when depressed and up, just at the bite point. DMF?
Dec 4, 2019 at 2:18 AM
Just so I understand, you have the vehicle in gear and the clutch depressed. As you let it out and it begins to grip, it makes a noise in the engine?
If this is the case, can you get a recording of it? More than likely this is something in the throw out bearing if it is a bit of a grinding noise.
Dec 4, 2019 at 8:24 AM
