I replaced the clutch, pilot bearing, throw out bearing and transmission ten years ago. been working fine until three weeks ago when it would not disengage all the time and was hard to get in gear and started grinding. Pulled the transmission and found the throw out bearing was dry and spitting out the needle bearings and grabbing the input shaft keeping it spinning.
The flywheel was turned seventeen years ago and the flywheel was turned again this time, but this time it had burn marks and heat cracks in it.
Is it possible the machine shop took too much off to clean it and now the clutch is farther away from the throw out bearing to let it disengage properly?
I have bled this thing over an hour and it still only disengages a quarter inch from the floor. what is the minimum thickness of the flywheel?
Feb 4, 2018 at 2:30 PM
