Clutch doesn't work it is very low near the ground therefore I can't change gears
50,000 MILES • 1.0L • 4 CYL • FWD • MANUAL
BULENT94
Basically for about a month or two my clutch was stiff I always had to force it down hard to change gears especially to gear 1. Yesterday as I pushed the clutch down I heard a noise then after that the clutch was very low and literally impossible to change gears. I am wondering if the whole clutch needs changing or is it a part in the clutch ? Any suggestions would help thank you very much.
It's a VW POLO 2001 (6N2) 1.0L
Aug 21, 2014 at 5:48 AM
  • 110,248 POSTS
The first thing I would check is the clutch cable itself. See if it is broken. Have a helper move the clutch pedal in the vehicle while you check to see if there is movement at the transmission.
Aug 21, 2014 at 11:32 AM
