Heard a metallic click and clutch pedal dropped to the floor
255,220 MILES • 4 CYL • 2WD • MANUAL
JESSICA L SMOCK
I was driving home and I heard a metallic click and suddenly my clutch pedal dropped to the floor! What would cause this? My clutch is not hydraulic.
Apr 3, 2019 at 12:07 AM
JOETECHPRO
  • 705 POSTS
Hey Jessica L Smock,
It does look like the clutch on your vehicle uses a hydraulic system.
Did the click sound like it was from inside the car by your feet or from inside the engine bay?
If from inside the car have a look down at your clutch pedal, lift the pedal and trace where it would attach to. there will be a rod that goes through the bulk head that the pedal should be attached to. If it is attached and moving the rod then more than likely the slave cylinder/release arm is the issue.
It could be that the pin that connects the pedal to the rod that goes through the bulkhead has broken/fallen out. Let us know if the pedal is connected or if it has broken the pin.
Regards, Joe
Apr 3, 2019 at 10:02 AM
