clutch chatter
5,000 MILES • 5.5L • V8 • RWD • MANUAL
FRAMEOFF
I have a L-34 with a frame off restoration.
The 396 has been rebuilt, so I doubt I have oil on the clutch plate. I had the flywheel surfaced, new clutch plate pressure plate, throw out bearing, pilot bearing. I have real bad clutch chatter when I let out the clutch. I was told that it might be the motor mounts, so I changed the new factory mounts, for polyurethane mounts, It did seem to help but the problem is still there. I have changed all the universal joints as well. The only thing I did not mess with is the twelve bolt rear end, it seems to be alright. I have installed a lot of clutches in my day, but this baffles me.
Thanks for your help.
Dean
Mar 5, 2017 at 11:45 AM
  • 55,711 POSTS
Yes, clutch chatter is everything to do with the clutch disc, pressure plate and flywheel, when you say resurfaced do you mean re-machined? Because hitting it with a gasket gun will make it chatter. Also the quality of the clutch will play into things as well. Is it a new clutch not rebuilt? If new what kind is it?
Best, Ken
Mar 6, 2017 at 10:32 AM
FRAMEOFF
Thanks Ken. I did have the flywheel surface ground, as for the clutch plate I don't know if it
was new or rebuilt. Most of the clutch kits I looked at where either made in Mexico or China
so I suppose that is a lot of my problem.
Mar 6, 2017 at 10:09 PM
HMAC300
  • 48,601 POSTS
one thing you might try to cure it is to make it slip on purpose b y playing with the pedal, making it move not fully engaged, sometimes that will take care of it
Mar 6, 2017 at 10:14 PM
  • 55,711 POSTS
Yep it will be, getting a new clutch will be the way to go, it wish I had an easy fix for you but I have done many clutches in my day and know what it takes to get them to work right.
Please let me know what happens,
Best, Ken
Mar 7, 2017 at 3:45 AM
FRAMEOFF
Thanks Ken. Do you have a clutch name brand you like, I really don"t know if there is any made in the
u.s. anymore.
Mar 7, 2017 at 7:02 AM
  • 55,711 POSTS
This one here look pretty middle of the road price wise and RAM clutches are pretty good.
https://www.amazon.com/gp/product/B000ML35YU/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B000ML35YU&linkId=9d8255d50e6d07c460f624fa87699360
Make sure no oil or grease gets one the disc/flywheel
Let me know how it goes
Best, Ken
Mar 7, 2017 at 7:43 AM
HMAC300
  • 48,601 POSTS
luk is original equipment on GM vehicles
Mar 7, 2017 at 8:37 AM
