Transmission fluid
85,400 MILES • V8 • RWD • AUTOMATIC
CHARLIE9859
How much transmission fluid does an automatic 350 V8 need?
Thanks!
Mar 13, 2017 at 12:26 PM
CARADIODOC
  • 34,415 POSTS
Can't find that in my reference material, which is probably why no one replied already. I'll keep searching, but in the meantime, we never worry about capacities because it takes too much of our customers time to be looking up things like that. A typical capacity for a three-speed would be around nine quarts. I'd start with six or seven, then, when you feel it go into a gear, run it through all the gears, stopping in each one for a few seconds, put it in "park", then check the level. Keep adding until you get to the level shown on the dip stick.
Mar 15, 2017 at 11:08 AM
