Did I burn up the clutch?
120,143 MILES • 2.2L • 4 CYL • 2WD • MANUAL
AZDANNO04
  • 378 POSTS
While driving I was shifting gears, but I noticed the smell of when I was pressing to much of the gas but then I wasn't getting any grab of the gears and I'm pretty sure I burnt the clutch out. This my first five speed.
Oct 26, 2021 at 5:56 AM
Good afternoon,
Yes, it definitely sounds like you burned up the clutch.
It will have to be replaced.
I attached a YouTube video for you to view of removing the transmission to access the clutch.
https://www.youtube.com/watch?v=Nr-sGylv3ts
Oct 26, 2021 at 7:46 AM
AZDANNO04
  • 378 POSTS
Still need a bit more details on removing the transmission. I have checked to make sure no bolts are still in and disconnected wiring.
Nov 14, 2021 at 8:32 PM
Where are you at this point?
Can you post some pictures?
Nov 14, 2021 at 8:42 PM
