I have a hard time shifting into 1st and 2nd gear
147,000 MILES • 4.0L • 6 CYL • 4WD • MANUAL
CAMDRISKILL
When I drive over 40 miles I have a hard time shifting into 1st and 2nd gear. You can hear a loud bang when it goes into gear. It doesn't do it on short trips below 40 miles.
Apr 19, 2021 at 4:06 AM
Sounds like you need a clutch. What happens is when the clutch and fluid heat up they stop operating properly and the clutch doesn't completely disengage which makes it had to shift.
Here are a lot of guides on this:
https://www.2carpros.com/articles/clutch-symptoms
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.2carpros.com/articles/throw-out-bearing-replacement
https://www.2carpros.com/articles/pilot-bearing-replacement
Plus below is the process on how to replace the disc from the manual.
I would replace the entire system including the slave cylinder, pressure plate, and disc.
Please let us know if you have other questions about this and we can go from there.
Thanks
Apr 20, 2021 at 10:00 AM
