the clutch feels like it has less pressure on it
190,000 MILES • 3.6L • 6 CYL • 4WD • MANUAL
DJRAMNOW
I can shut the truck off and put it into gear then take off. It's a manual transmission. Also the clutch feels like it has less pressure on it now as well. Transmission fluid is good also.
Dec 11, 2019 at 10:10 AM
  • 55,721 POSTS
This happens when the clutch disc starts to fall apart it wont disengage. Here is a guide to help confirm the issue with a video of a clutch replacement being done in a similar car (the process is the same):
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
and
https://youtu.be/JpzefqEeVGE
and
https://youtu.be/EpBMj5ZY_bo
May 3, 2021 at 7:21 AM
