clutch
2007 DAIHATSU TERIOS
150,000 MILES
GAMM
When I left the clutch to biting point after changing gears a knock noise happens. When i put the car in 4wd mode the noise disappears car works perfectly. Also when changing gears a grinding noise occurs can you please help me much appreciated.
May 25, 2013 at 12:01 AM
KHLOW2008
  • 41,814 POSTS
I believe this vehicle is AWD and when you engage the 4WD, it is in fact locking the differentials to be equal for both ftont and rear.
I would suspect the transfer gear needs to be checked, most probably the chain within the transfer is worn..
May 25, 2013 at 1:23 AM
GAMM
Where would I find the transfer gear/chain is it in the engine? I was also told that problem is the axle I replaced a new axle but the problem never went away could the problem be from their. Thank you for your time and help
Jun 6, 2013 at 3:55 AM
KHLOW2008
  • 41,814 POSTS
Transfer gear is the one at rear of transmission where the driveshafts comes out to be connected to front and rear of vehicle.
Jun 6, 2013 at 4:05 AM
