clutch slave cylinder every time starts leaking?
1,160,000 MILES • 1.3L • 4 CYL • TURBO • 2WD • MANUAL
JORO89
  • 7 POSTS
hi, I replies to my clutch on my vehicle listed above mk3 1.3 cdti. When I bleed the slave cylinder every time the cylinder starts leaking i tried three cylinders and every time the same thing. i put the old clutch back in and put a new bearing and it leaked again. where could the fault be?
Feb 7, 2025 at 2:18 AM
  • 55,711 POSTS
That a good one, are they high quality parts like OEM? It could be the clutch assembly is having an issue and allowing the secondary cylinder to overextend. Did you notice anything strange also is this secondary cylinder external to the transmission?
Feb 8, 2025 at 2:37 AM
JORO89
  • 7 POSTS
hi thanks for responding. yes, all parts are OM identical to the original I just take down pedal cylinder or replace it because I think it's not released a pressure from the bearing when I press the pedal down and that build a double pressure and that's why the bearing come too far. And like I said, I put the old flywheel with the old clutch and happen exactly the same, and the difference between the old clutch and the new clutch is not a big difference. It's like a one meal. That's why I think the car was on a semi-clutch, and that's why the bearing didn't return all the way because of this pump.
Feb 8, 2025 at 2:58 AM
  • 55,711 POSTS
Yep, if the cylinder overextends it will leak. Did the clutch ever work since you had the car?
Feb 9, 2025 at 1:28 AM
JORO89
  • 7 POSTS
very hard to say we just buy it not used mach but last 2 times was slipping with higher speed.
Feb 9, 2025 at 1:40 AM
  • 55,711 POSTS
If the clutch disc is falling apart, it will cause the pressure plate fingers to be inset which can cause the extended travel.
Feb 9, 2025 at 5:09 AM
JORO89
  • 7 POSTS
yes I am waiting now for master cylinder and when I put back everything again. I will let you know what happens.
Feb 9, 2025 at 5:12 AM
  • 55,711 POSTS
Sounds good, thank you.
Feb 10, 2025 at 1:47 AM
JORO89
  • 7 POSTS
hi all, done now problem was in this master cylinder.
Feb 21, 2025 at 5:57 PM
JORO89
  • 7 POSTS
It was not released the pressure all the way back to the tank and that's why I was building a double pressure since I put the new one straight away go on and it's fine.
Feb 21, 2025 at 6:00 PM
  • 55,711 POSTS
Good job, can I ask if the clutch stayed disengaged while this was happening?
Feb 22, 2025 at 4:21 AM
JORO89
  • 7 POSTS
It was happening when the pedal was engaged.
Feb 22, 2025 at 5:14 AM
  • 55,711 POSTS
Yes, but if the clutch was "over pressured" it would be disengaged the entire time?
Feb 23, 2025 at 1:47 AM
