clutch pedal went to the floor?
127,522 MILES • 4.3L • V6 • 2WD • MANUAL
LILLIEP
My clutch has been making a squeaky noise for a few months. Today I got in my truck pressed the clutch and turned key to crank it and the clutch hit the floor and it did not crank and it jumped forward about hitting a tree. So, I know my clutch is gone so went online to try to price and order parts I do not have the owner's manual for parts or part
numbers, also I am not sure exactly what to order.
Can anyone help??
Aug 22, 2023 at 7:27 AM
  • 110,248 POSTS
If the clutch pedal went to the floor, chances are either the clutch master cylinder is faulty or the slave cylinder.
I attached pictures showing both. Do me a favor. First check the clutch master cylinder reservoir and make sure it is full. If it isn't, add Dot 3 brake fluid to fill it. See if that changes things. See pic 1
If the reservoir is low, check the clutch master cylinder and lines to see if there is a leak.
If there are leaks but the reservoir was low or empty, go to the transmission bell housing and locate the slave cylinder. See pic 2. Check for evidence of a leak there.
Aug 22, 2023 at 1:21 PM
LILLIEP
Okay, I had already checked, and it was empty. So, I filled the reservoir and got in the truck and pushed the clutch no change, but all the fluid leaked out. I had to go to work but when I got home, I'm going to get under it and see what I can find and I'll let you know, and thanks again.
Aug 23, 2023 at 4:43 AM
  • 110,248 POSTS
Thanks for the update. It is likely the slave cylinder, but it could be the hose itself.
Let me know what I can do to help or if you have questions.
joe
Aug 23, 2023 at 12:45 PM
