Clutch keeps going out
120,000 MILES • 4 CYL • 2WD • MANUAL
JENNIQUALLS
I have replaced my clutch 3 times in 6 months. And now it has gone out again. Is there something else mechanical that can be causing my clutch to continually go out ?
Oct 25, 2020 at 7:50 AM
Good morning,
Some reasons are below.
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.2carpros.com/articles/inner-workings-of-a-car-clutch
1. Quality of the parts. You need to use a new clutch assembly. OEM parts are the best
2. Flywheel. If the flywheel is warped or too this, it will overheat the clutch and cause premature failure. A new flywheel is always installed when I replaced the clutch assembly.
3. Adjustment of the free play for the pedal. If the free play is not correct, it will burn out the disc in a short period of time.
4. Driving habits. If you ride the clutch while driving, it will burn up the clutch.
5. Pilot bushing worn out or not replaced causing the input shaft to wobble.
6. Air in the hydraulic line for the clutch. I attached the bleeding process for you to check for no air.
Oct 25, 2020 at 8:39 AM
