Clutch is not depressing all the way and does not allow the transmision to go into gear
187,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
DOO
  • 7 POSTS
Clutch feels like it is bending something. it wont depress all the way and wont go into gear.
Oct 24, 2016 at 6:48 AM
SATURNTECH9
  • 30,869 POSTS
So what model is this ?
Oct 24, 2016 at 1:27 PM
DOO
  • 7 POSTS
The make box on my registration says SS and body style says SL4D.
Oct 24, 2016 at 1:38 PM
SATURNTECH9
  • 30,869 POSTS
What it would say SL1 SL2 LS1 LS 2 etc? Do you have any pictures of the cars you can post?
Oct 24, 2016 at 1:43 PM
DOO
  • 7 POSTS
Here are a few. It is only four lug. Not five as the wheel caps indicate.
Oct 24, 2016 at 2:13 PM
DOO
  • 7 POSTS
I did post another question with more details. I left out that it usually grinds into third and clunks when turning sometimes as well.
Oct 24, 2016 at 2:15 PM
SATURNTECH9
  • 30,869 POSTS
Looks like a SL1 if the. Front seat does not have a separate head rest that comes off the seat on two metal posts? So does the clutch pedal have pressure going all the way down? Or does it drop some then have pressure?
Oct 24, 2016 at 2:41 PM
DOO
  • 7 POSTS
I will check again later on, I am at work now, but I think there is pressure at beginning then stiffens up as it goes down.
Oct 25, 2016 at 5:11 AM
  • 55,732 POSTS
It sounds like the clutch pressure plate or fork has broken. Or the clutch master cylinder is bad, Is the brake fluid low be cause it is the fluid that works the clutch.
Please let us know what you find so it will help others.
Best, Ken
Oct 27, 2016 at 3:45 PM
SATURNTECH9
  • 30,869 POSTS
That one doesn't use fluid from the master cylinder it has its own fluid.If you have pressure from the top of the clutch pedal to the floor the clutch master and slave cylinder are good.
Oct 28, 2016 at 1:23 AM
