clutch feels like it needs pumped up
100,000 MILES • 6 CYL • 4WD • MANUAL
SUSAN MCCOY
Hi, my clutch feels like it needs pumped up. it is mushy and having trouble putting it in gear.
Mar 12, 2017 at 8:52 AM
This is almost always due to air in the system due to a leak.
Here are a few guides that will help with this:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.2carpros.com/articles/pilot-bearing-replacement
https://www.2carpros.com/articles/throw-out-bearing-replacement
If it were me, I would just get a clutch kit and replace the entire system as this is likely due to a slave cylinder leaking. So, if this is the case then when you go in and replace the slave, I would again, replace the entire clutch while you are there.
I am attaching the entire process from the manual on how to do this. Please run through this material and let us know what questions you have. Thanks
Oct 14, 2021 at 11:43 AM
