Clutch
220,000 MILES • 0.5L • 3 CYL • 4WD • MANUAL
MUSTANG-SALLY05
Whirring noise, as I release clutch and shift into second and third. Noise stops soon after.
Mar 5, 2018 at 8:43 AM
Good evening.
Is the noise only when you push in the clutch?
Mar 5, 2018 at 10:25 AM
MUSTANG-SALLY05
Hi there Roy,
Yes, only when I am pressing in the clutch does it make the noise.
Mar 6, 2018 at 11:02 PM
Okay, thanks.
You need a throw-out bearing in the clutch assembly. there is a bearing in the assembly and when it wears out, it will make noise only when you apply pressure to the bearing.
If you replace that, then you should replace the pressure plate and disc as well.
Mar 6, 2018 at 11:10 PM
