Cluster lights not working
160,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
RD66
  • 61 POSTS
I need a wiring diagram for the dash lights, i want to check the cluster for voltage.
Apr 18, 2022 at 12:43 AM
  • 110,248 POSTS
I wasn't sure exactly what you were looking for because cluster warning lights are listed differently than cluster lighting. So, I attached the schematics for both.
The first two pics are of the interior lighting which includes cluster lighting. Pics 3 and 4 are the circuits for the cluster itself, warning lights, gauges and so on.
Originally, these were one page each. I had to cut them in half to make them readable for you, but I did overlap them so you can follow from one to the next.
Let me know if this helps.
Apr 18, 2022 at 10:51 AM
RD66
  • 61 POSTS
Thank you Joe.
Apr 18, 2022 at 2:55 PM
  • 110,248 POSTS
You are very welcome. Let me know if there is anything I can do to help and if you are able to find the problem.
Apr 19, 2022 at 9:37 AM
RD66
  • 61 POSTS
The dash lights are working again, not sure what happened but i suspect a loose connection.
Apr 20, 2022 at 8:40 AM
  • 110,248 POSTS
That is what it sounds like. Check up under the dash and make sure the connectors are tight.
Let me know if things change or if I can help.
Apr 20, 2022 at 1:39 PM
RD66
  • 61 POSTS
Yes sir, thanks.
Apr 20, 2022 at 5:46 PM
