After replacing dash (cluster) the gauges are not working
197,000 MILES • 5.7L • V8 • 2WD • MANUAL
WHYNOTME926
  • 10 POSTS
I replaced my dash and I put back in the cluster now the gauges are not working. is there a ground wire that I'm missing?
Dec 11, 2020 at 7:34 AM
If the entire cluster is not working then you are on the right path but I don't think it is a ground. The ground for this is G100 which is on the fender on the driver side. So you would not have taken that off if you did the dash.
The most likely cause is one of three things. First the connectors on the cluster are not fully seated so you should double check them. Second, one of the fuses blew. Third, the cluster got damaged when you had it out.
Here is a guide that will help with testing the fuses if needed:
I attached the wiring and fuse information. Let's check these things and go from there. Thanks
Dec 11, 2020 at 9:37 AM
WHYNOTME926
  • 10 POSTS
Thank you it was in fact one of them. The connectors were put back in upside down. I'm so glad it was an easy fix and back to working. Thanks so much.
Dec 12, 2020 at 2:43 PM
That is awesome and thanks for updating us. I am sure that will help others in the future if they have a similar situation.
Thanks and come back to 2CarPros next time.
Dec 13, 2020 at 8:24 AM
