fuel gauge inaccurate
176,501 MILES
VETT 2010
Fuel gauge not actually.
Oct 9, 2016 at 11:27 AM
AL514
  • 5,683 POSTS
what is wrong with your fuel gauge? not working?
Oct 9, 2016 at 1:24 PM
VETT 2010
when fuel is empty gauge still shows there is fuel in the tank.
Oct 9, 2016 at 8:28 PM
AL514
  • 5,683 POSTS
the diagnostic start on this would be to check for DTCodes, there is a code for the sending unit, is the check engine light on? The gauge is controlled by the float in the gas tank. I would start at the tank with the float/sending unit. With a multi-meter check the resistance of the unit while moving the float up and down. Considering all the information for the dash gauges is send on a data wire from the ECM and its only the fuel gauge acting up. Start at the tank, make sure the ground wire has low resistance also. Here is a wiring diagram to help (wires are highlighted in yellow). I have seen many sending units in the tank go bad. Hope this helps.
Oct 9, 2016 at 9:08 PM
