Clunks over bumps
150,000 MILES • 3.5L • 6 CYL • RWD • AUTOMATIC
BOBBY300
I replaced struts inner tie rod's took to mechanics and brakes plus they say everything under there is tight but it makes a clunking noise over bumps? ?? Talk to me
Jan 2, 2016 at 12:11 PM
JOHNNYT73
  • 924 POSTS
This could be few things but I would look into the sway bar links and/or the sway bar bushings. The links will always seem tight when checking them. Only over bumps will they generally make a knocking or clunking type noise. Also check the control arm bushings.
Jan 2, 2016 at 10:14 PM
BOBBY300
Okay will do
Jan 3, 2016 at 12:08 AM
