front sway bar bushings replacement instructions needed
160,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
HKFROMNY.
  • 112 POSTS
I was told my front sway bar bushings need replaced. Been looking for video showing me where they are located and how difficult to replace, but cannot get my model of car, comes up with trucks or chargers and such.
May 21, 2021 at 11:27 AM
HARRY P
  • 2,292 POSTS
Hello. The best I could do was to find the instructions on replacing the stabilizer bar, which includes steps removing and reinstalling the bushings. It's a fairly straightforward job to do, so I suspect that you can do it.
Good luck and let us know how it goes.
May 21, 2021 at 8:43 PM
HKFROMNY.
  • 112 POSTS
From what i'm seeing, figure it, this whole removal step of cross member isn't needed, can can easily access the four bolts themselves (bushing bolt}?
May 22, 2021 at 1:40 AM
HARRY P
  • 2,292 POSTS
Yeah, I think you're right. I don't see why that cross member has to go anywhere for just the bushings.
May 23, 2021 at 10:41 PM
HKFROMNY.
  • 112 POSTS
well, with further investigation, found out my bushings aren't the only cause of the noise, my rear motor mount is rusted away. got new from Rock Auto on the way. We'll see after they installed what's what.
May 23, 2021 at 11:18 PM
  • 55,710 POSTS
May 26, 2021 at 3:37 AM
HKFROMNY.
  • 112 POSTS
Thanks for checking in, still waiting for rock auto delivery, should be a relatively easy process once it arrives. but, should I need anything like pry bars? doing this on my dirt driveway, have all normal safety measures in place. wish me luck...lol
May 26, 2021 at 4:08 AM
  • 55,710 POSTS
Yes, a large pry bar will make the job easier. please put wood down to help hold the car up. this guide can help you stay safe:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
May 28, 2021 at 3:43 AM
HKFROMNY.
  • 112 POSTS
Hey guys, all's well and good. Got the mount changed with the normal busted knuckles. Wanted to change the sway bar bushings but can't even get good access to the bolts. My local mechanic will have to do it, the subframe needs to be loosened to do it. As always, thanks for being there.
May 28, 2021 at 4:41 AM
  • 55,710 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
May 30, 2021 at 4:41 AM
HKFROMNY.
  • 112 POSTS
That I have done, while i'm thinking about it, on this car it has the CVT Sealed transmission but i did a gasket and oil change on it and noticed the transmission has the same wet gasket area that oil pan did. Is there anything I can do as far as drain it, change the gasket and fill with CVT transmission fluid myself? Or is that not advised?
May 30, 2021 at 5:38 AM
  • 55,710 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Jun 1, 2021 at 2:57 AM
