Clunking on hard acceleration?
97,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
BEETLEPUNK21
  • 127 POSTS
When I’m at a stop, and I press on the gas hard, there is a clunking noise. It does not do it in reverse. And it only does it when there is hard acceleration.
Would you say it’s the U joints on the driveshaft?
Or could it possibly be the CV axles in front?
This car is all wheel drive.
May 6, 2024 at 8:50 PM
BEETLEPUNK21
  • 127 POSTS
P.S. how can I check/test either of these?
May 6, 2024 at 8:51 PM
  • 110,248 POSTS
If the sound is coming from the front of the vehicle, chances are it is related to one or more of the CV joints or you may even have a faulty engine mount.
As far as the CV joints, here is a link that discusses common symptoms related to failure:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
As far as the drive shaft U-joint, to properly check it, the drive shaft needs to be removed.
Here is a link that explains how to check one:
https://www.2carpros.com/articles/how-u-joints-work
Note: Usually, a failing universal joint will make a clunk sound when you place the vehicle in gear.
Let me know what you find.
May 7, 2024 at 12:18 PM
