Clunking Noise When braking
32,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
OZZIE303
There is a clunking noise only when braking
Feb 18, 2018 at 10:58 PM
KHLOW2008
  • 41,812 POSTS
Where brakes are concerned, abnormalities should be attended to immediately as this is a safety concern.
Something is loose/worn or damaged with the brake and/or related parts and clunking noise could be anything. You need to diagnose where the noise is coming from and proceed with rectification.
Have the brake system checked. Check for worn wheel bearings, pads, disc.
Feb 19, 2018 at 11:24 AM
