Clunking noise in front end and jolting forward
2000 MITSUBISHI ECLIPSE
180 MILES
BECAUSERACECAR1994
When I drive on a rough road or over a bump my car makes a clunking sound from the front end. Only happens at low speeds. Only happens occasionally, usually when I don't drive it for a few hours.
Also, when I let off the acceleration my car slightly jolts forward and slows down. In order to get back up to speed I have to really get into the pedal. At that point my RPM's rise then jump back down. Other than that drives great. Ive only had the car for a month and already had to replace the starter. I was originally filling up with regular 87 octane gasoline. Since last week I've been using 89 octane could that have something to do with it? Help!!!
Oct 13, 2013 at 4:23 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure. clean throttle plate on both sides with choke cleaner and iac hole. have a pro check front end for bad struts and control arm bushings.
Oct 13, 2013 at 11:42 PM
