Thank you very much. How can I tell for sure if that's the real problem or not?
Oct 2, 2020 at 3:40 AM
✓Experienced Mechanic
You will need a second person in the car to put it in reverse with there foot on the brake and parking brake set and give it gas. The motor will likely move and you need to see which mount is allowing the movement.
You are welcome.
Oct 2, 2020 at 3:41 AM
HAP
MEMBER
Also, (I don't if it's related or not) the ABS (and sometimes the traction control) light comes on when I'm driving on bare pavement. And according to a plug-in scanner, all the wheels are spinning at the same speed.
Oct 2, 2020 at 5:46 AM
Not related at all.
If you want to work with the ABS issue, you will need to start a new question.
We can only answer questions on one issue at a time.
Oct 2, 2020 at 5:57 AM
HAP
MEMBER
Okay.
Oct 2, 2020 at 6:50 AM
Keep me updated.
Oct 2, 2020 at 6:51 AM
HAP
MEMBER
I will. Thanks Roy.
Oct 2, 2020 at 6:58 AM
You are welcome.
Always glad to help.
Oct 2, 2020 at 7:03 AM
