Clunk while accelerating.
198,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
LARAERAE
I just put 24" rims on my truck and one of the tires got a bubble. So I put 1 stock rim and tire on while other is repaired. But it started making a clunk/ thumping under my foot, only while accelerating. I then put a second stock rim on to even it out, but still doing same thing. Is it just because of different rims in front than back? What can it be? Please help thank you.
Rachel
Mar 27, 2017 at 3:41 AM
STEVE W.
  • 15,418 POSTS
Only putting on one stock sized tire has probably damaged either a U-Joint, the differential or the transfer case. Only way to tell for sure is to put it up in the air and check for damage. The reason is that the different sized tires rotate at different speeds. This causes the various parts to turn at different speeds relative to each other and that can easily do damage, especially on a vehicle that already has high mileage. I hope it turns out to be something like a mount or just a U-Joint.
Oh and keep the spare tires handy. Unless you live in an area with no pot holes or rough pavement, you will be using them more. The thin sidewalls on tires that will fit your vehicle with 24 inch rims are going to take a beating.
Mar 28, 2017 at 12:40 PM
