Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
300
Brakes
ABS
Wheel Speed Sensor
Replace/Remove
I found wrong was a wheel sensor wiring broken
2008 CHRYSLER 300
213,855 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JR47
MEMBER
I checked all the brakes and the only thing I found wrong was a wheel sensor wiring broken so I need to replace it, right front please?
Sep 20, 2019 at 8:12 AM
Experienced Mechanic
This guide will help with the replacement:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Below is the process from the manual that will give the detail that you need to replace this.
Please let us know if you have other questions. Thanks
Images (Click to enlarge)
Mar 10, 2021 at 9:56 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
