Clunk noise
171,000 MILES • 2.0L • 4 CYL • AUTOMATIC
TOMMY CHONG PELLETIER
Hello, recently when driving i would pull up to a red light or stop sign and as I am taking off at low speed I hear this clunk noise under my car and then it takes awhile to pick up speed and all the symbols come up at once ( P,N,D,R,1,2) and check engine light kicks in. I will park the car at home then the next day the engine light will be off, but the same problem will occur when i go for a drive.
Sep 15, 2016 at 4:31 AM
HMAC300
  • 48,601 POSTS
have it scanned for codes auto parts may pick it up, but a mechanics scanner should if auto parts wont.
Sep 15, 2016 at 4:58 AM
Had it scanned and they told me it needs a engine tune up... plugs and wire's.. did that and problem still occured.
Sep 20, 2016 at 4:47 AM
HMAC300
  • 48,601 POSTS
sounds like a misfire have them scan for codes then freeze frame it.. it may be another sensor gone bad causing it.
Sep 20, 2016 at 6:34 AM
