Clunk going into forward/reverse and vibration on acceleration?
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
CHARLES WILBUR
  • 10 POSTS
clunk noise sounds like coming from rear of car there is also some sound that comes from rear of car that comes and goes at different speeds.
May 4, 2023 at 11:45 AM
  • 110,248 POSTS
If you get noise and vibration, my first suspect is a worn universal joint. I'm not sure if you checked them, but that is certainly where I would start.
Take a look at this link. Note the link is to help diagnose a universal joint issue and explains in general how to replace one.
https://www.2carpros.com/articles/comprehensive-guide-to-checking-and-replacing-an-automotive-drive-shaft-u-joint
May 4, 2023 at 1:00 PM
