clock spring
425,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
JDNDON
Had to install new power steering gear forgot to remove negative battery cable. After installation cranked and will idle but will not accelerate. Could I have damaged the clock spring during installation of power steering gear?
May 20, 2018 at 10:50 AM
  • 55,682 POSTS
Yes, the clock spring can be damaged when doing the steering box. Did you turn the wheel a bunch of times? This will do it. Here is a guide to help you see what you are in for:
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Cheers, Ken
May 24, 2018 at 5:39 AM
