Would a bad clock spring cause my truck not to start?
Mar 14, 2019 at 12:59 PM
✓Experienced Mechanic
A clock spring won't prevent the engine from starting. What is happening?
Mar 14, 2019 at 2:01 PM
MELISSA LAUR
MEMBER
You can turn the key and have power. (Checked battery charge is good.) Turn the key you get nothing.
Mar 14, 2019 at 2:06 PM
Okay, that can be a few things. The first thing that should be checked is if the car starts in neutral. If not, I need you to check for power to the starter itself. I will provide a link that explains how it is done. You will need to use a volt meter, so I will include directions for that, too.
Let me know if this is something you feel comfortable trying. If not, I will try a different approach.
Mar 14, 2019 at 2:25 PM
MELISSA LAUR
MEMBER
I will most definitely be trying this once day breaks. I will keep you updated.
Mar 14, 2019 at 3:00 PM
Welcome back:
Let me know the results, if you have other questions, or need help.
Mar 15, 2019 at 12:00 PM
MELISSA LAUR
MEMBER
One of the wires connected to the starter was completely off! After cleaning the connections and replacing a nut we are up and running. Thank you so much.
Mar 15, 2019 at 12:24 PM
Welcome back:
That will do it. I'm glad you found it and you are very welcome.
Take care, and let us know if you have questions in the future.
