climate control stuck on upper vents
135,000 MILES • 1.7L • 4 CYL • FWD • AUTOMATIC
TEXPACK88
vents will only blow to top will not switch to defrost or bottom to feet did hvac system self check and got a code 10 would like to know what that code means
Jan 5, 2015 at 2:40 AM
CADIEMAN
  • 3,544 POSTS
THE IAT (INTERNAL AIR TEMPERTURE) SENSOR IS DISCONNECTED OR BAD AND WILL NEED TO BE REPLACED. IT'S MOUNTED IN THE TOP DASH. THE DEALER CAN HELP U WITH THE EXACT LOCATION.
Jan 5, 2015 at 3:12 AM
