Can i use a climate control module if the part numbers are not the same but similar?
2006 NISSAN MAXIMA
133,013 MILES • V6 • 2WD • AUTOMATIC
DJ JOCKS
i gave Nissan dealer my VIN, they said the new part will fit my car although it isn't the same part number (part numbers are similar).
Jun 10, 2022 at 4:57 PM
  • 110,194 POSTS
Oftentimes, part numbers are replaced with new numbers. I'm not sure if that is what you are dealing with, but it is very possible that they are correct.
Keep in mind, manufacturers can use different part numbers for the same replacement part depending on the year, and model.
If you let me know the numbers, I will try to cross-reference them to see if they are the same.
Jun 10, 2022 at 10:08 PM
