Climate control not working
189,008 MILES • 4.3L • V6 • 4WD • MANUAL
HALLEY MCGINLEY
Have no lights on the climate control panel and it's not working no fan or heat or A/C.
Oct 29, 2021 at 6:25 AM
  • 110,248 POSTS
If nothing is working, first I need you to check the fuse for the circuit. The fuse box should be on the driver's side under the instrument panel. In addition to checking the fuse's condition, it is important to make sure there is power both to the fuse and out from it.
Let me know what you find.
See pic below.
Oct 29, 2021 at 2:20 PM
HALLEY MCGINLEY
All of those fuses are good. So, i'm guessing it's more than likely a wiring issue but we can't find a diagram for it.
Oct 30, 2021 at 1:22 AM
  • 110,248 POSTS
Do me a favor. I was able to dig up older factory wiring schematics related to the circuit. Take a look through them and let me know if they help. Also, here is a link you may find helpful:
Oct 30, 2021 at 1:19 PM
