Climate control not working
70,000 MILES
TLYNNCH
When I turn the fan speed switch on the speed and air flow setting shows on the digital display but the neither AC compressor or fan operate.
Sep 20, 2017 at 12:46 AM
  • 55,594 POSTS
There are several fuses that run the system and there is a blower module that can go out causing the problem you have described. that need to be checked. Here are some guides and diagram (below) so you can do some easy testing so we can get the car fixed.
This guide should help as well.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
The guide has the module with the blower motor.
Please let us know what happens and upload pictures or videos of the problem.
Cheers, Ken
Sep 21, 2017 at 6:08 AM
