Climate control
1,000,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MTCHEVY.
Turn on auto for heater and defrost usually A/C light is on now it flashes and turns off.
Dec 18, 2017 at 2:25 AM
Good afternoon my name is Roy and I will assist
Does the A/C system produce cold air? You may have an issue with the A/C system such as, low Freon, leak in system or compressor.
Dec 19, 2017 at 12:15 AM
MTCHEVY.
Hi Roy I’m on the road now and it’s very cold when I get to my location I’ll be able to try the a/c. I’ll get back to you soon.
Thanks for getting back to me
Dec 19, 2017 at 10:59 AM
Your welcome.
Keep me updated
Dec 19, 2017 at 9:17 PM
MTCHEVY.
Good morning Roy
Ok got to my location had to go through los vagas a/c is working I’ll check the Freon & look for leaks today. Get back to you later.
Dec 21, 2017 at 2:36 AM
OK, sounds like a plan
Dec 21, 2017 at 2:42 AM
MTCHEVY.
Ok I don’t know that on newer vehicles that don’t have a inspection window.Look for leaks,broken lines nothing around condenser.stared it up & it got cold came to temp turn on heat & its ok. But I still don’t understand why the a/c light flashes & turns off when its on auto. No mention of this in the manual. I had someone say it’s the mixture door? Any way thanks again.
Dec 21, 2017 at 6:10 AM
Is the light still blinking with the ac system working at this time?? do all the modes change as commanded??
Dec 21, 2017 at 6:15 AM
MTCHEVY.
Ok went through all modes auto & manual every thing seems to work,I don’t understand but if it does act up again I’ll let you know.
To all of you at 2carptos & Roy thanks & marry Christmas
Dec 21, 2017 at 7:05 AM
thank you. same to yourself and your family.
Dec 21, 2017 at 7:21 AM
