Climate control not working after disconnecting the battery?
191,000 MILES
DEB61
After disconnecting battery the climate control won’t work fuses checked by auto technician all ok apparently.
Apr 20, 2025 at 11:45 PM
  • 55,770 POSTS
I would do a hard system reboot which should fix the problem, here is a guide to help you:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Please go over this guide and get back to us.
Apr 22, 2025 at 4:12 AM
DEB61
Ken L
Many thanks for this information have tried all options with no luck all fuses checked but now suspect it can only be the climate control unit that has blown because unit dead no lights etc. Would you think the same?
Thanks again
Debbie
Apr 26, 2025 at 2:30 AM
  • 55,770 POSTS
This can happen due to a voltage surge which can occur when the new battery was installed. Here is how to change the unit out, I would check eBay for a replacement part. Check out the images (below). Let us know how it goes.
Apr 27, 2025 at 5:13 AM
