There is no air coming out the vent
2013 DODGE AVENGER
90,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MTZRAQUEL
We checked the fuse and the blower motor (it works). We can't seem what the problem is.
When it first stop working, there was a rubbery smell that came through the vents while it was still working. I turned off the car, when I started the car and turned on the A/C, it wasn't blowing any air.
Aug 21, 2019 at 7:50 AM
  • 110,240 POSTS
Welcome to 2CarPros.
I need clarification. The blower motor works but doesn't produce air flow? Does the air flow come from any of the other areas?
If the motor doesn't run, how was it checked? Also, does it run on any speed? Which fuse was checked? Does the burning smell return if you try to use the blower motor?
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Aug 21, 2019 at 12:14 PM
