Turn signals not working
165,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
BENEDETTI
Hello, where is the blinker relay and the blinker unit? I no longer have the blinker and warning. I changed the fuses the blinker went out immediately, so, it's not the fuses. Could you help me? The car listed above has a 2.5 cdi.
May 4, 2022 at 9:07 PM
Just to be clear, are any of the turn signal bulbs working or is it just the indicator in the cluster that is not working?
https://www.2carpros.com/articles/turn-signals-blink-rapidly
The relay for this is on the left side of the dash.
However, I am attaching the wiring diagram which will show that the relay would be the likely cause if the indicators and the turn signals are not working.
So, take a look at this info below and let me know if you have questions.
Thanks
May 5, 2022 at 11:36 AM
