Clicking will not start
120,000 MILES • V8 • 4WD • AUTOMATIC
MHCARS
I changed the fuel pump, overflow tank, valve gasket and plug wires. The solenoid is clicking there's a rhythmic thumping coming from the ABS module, and won't start.
Jun 26, 2019 at 6:09 AM
  • 55,721 POSTS
It sounds like the battery is weak and needs to be replaced. To be sure here is a guide to help confirm the issue:
and if bad this guide will walk you through the replacement:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Jun 27, 2019 at 8:50 AM
MHCARS
I tried to jump start and nothing is working. The check engine light lights up and nothing else on the dash moves or lights up. The windows do nothing. Still is clicking and abs still thumping. That's it.
Jun 28, 2019 at 4:23 AM
MHCARS
We took the battery in and they said it had 8 volts.
Jun 28, 2019 at 5:24 AM
MHCARS
We charged the battery and it started up. However I'm not sure why it wouldn't jump start.
I plan on taking the battery and have it load tested, along with the alternator for the heck of it. The truck was sitting for a few weeks, I'm hoping there both still good.
Thank you Sir.
Jun 28, 2019 at 9:21 AM
  • 55,721 POSTS
The battery is no good please replace it. Let me know.
Jun 29, 2019 at 9:48 AM
