clicking while in park
200 MILES • 4.6L • V8 • FWD • AUTOMATIC
TARAH SAY ANNA
  • 5 POSTS
Hi hope you can help mom of 3 bought used Ford expedition stop by drop off gift for my dad and while in park sounded like someone trying turn the truck on again than every 5 15 seconds same noise loud clicking no ac on please help if can thanks have a great day
Aug 27, 2016 at 2:30 AM
CJ MEDEVAC
  • 11,000 POSTS
You said no A/C
Do you know where/ can you see the A/C compressor on the engine while it is running?
WATCH OUT FOR THEM PESKY MOVING PARTS - THEY WILL GET YOU IF YOU AREN'T CAREFUL!
Can you see what is going on on the front of it when that awful noise is happening and not happening?
You turn
The Medic
Aug 27, 2016 at 10:15 AM
TARAH SAY ANNA
  • 5 POSTS
hi thanks for answering back I have not thought about ac due to its never used i thought it to be ignition idling up and down or something with alternator or .Question after I find the compressor what should i look for? again thanks for your help ps it's now dark out I'll need to do this tomorrow
Aug 27, 2016 at 10:34 AM
TARAH SAY ANNA
  • 5 POSTS
over 200 thousands miles some reason could not and forgot to type in first question
Aug 27, 2016 at 10:36 AM
CJ MEDEVAC
  • 11,000 POSTS
See if the racket occurs when something might be happening on the front of of the compressor (like w/ the clutch).
You'll understand if you see/ hear the clutch making the racket!
Your Turn
The Medic
Aug 27, 2016 at 10:56 AM
TARAH SAY ANNA
  • 5 POSTS
hmm hard to imagine since no clutch more like key being turned over on again while car is already on I will look at the compressor and let you know I'll get back tomorrow and let you know your and time is yours so when you can reply thanks I'm handy to oil change to changing tires just don't get this noise issue nor can I find much on it web wise so again ty for any help
Aug 27, 2016 at 11:36 AM
CJ MEDEVAC
  • 11,000 POSTS
Alrighty then
Compressor has a clutch
It's what 'engages' the compressor (the shaft/ rather pumping part of the a/c system)when you turn it on, sometimes the clutch gets messed up, sometimes it won't engage, sometimes it will drag/ grind along.
Here's the kicker, the part I wanted you to look for, If the COMPRESSOR is "locked up" (shot, can no longer turn). It may sit there minding it's own little torn up business,
Then the clutch and its pulley which are turning sorta happy go lucky while the engine runs, suddenly, from being turned on "ENGAGES" the compressor.
Well Mr. Compressor is broke and cannot/ will not turn at all
Clutch is now hooked to it.
Clutch/ Clutch pulley wants to turn but now the compressor is dragging it down, lots of times we get a terrible racket, burning belt, engine may wanna start stalling down.
See-uns how you said this racket is an off/on kinda noise, the a/c also cuts off and on when it's running, This is the sole reason I'm having you look at this as a possibility.
This may not be your problem, but this is a quick EZ way to eliminate the A/C compressor and clutch out of the equation. If this only happens when the clutch engages, The car may run just fine if you simply unplug the connector on the clutch on the compressor until you can replace the compressor.
The Medic
Aug 27, 2016 at 12:38 PM
CJ MEDEVAC
  • 11,000 POSTS
This is a "typical" a/c clutch in operation (yours may look a little different)
Notice the center part does not spin until it is called upon (turned on by you or normal operation turns it on and off)
When the center clicks in (engages) the compressor's internal shaft (pump) is now turning,
that is, unless the compressor is locked down.
The video I found shows a compressor working normally.
https://www.youtube.com/watch?v=kp8pXmlFq_w
Your Turn
The Medic
Aug 27, 2016 at 12:54 PM
TARAH SAY ANNA
  • 5 POSTS
get great morning thanks the video did help me find it faster it did look different and this was not the issue for did not stop at all and the noise was coming near back all plugs were checked hoses tight sorry you had explain it that way but it anything else it could be thanks for your time if you don't get back today I understand it's your time thanks aagin
Aug 28, 2016 at 1:03 AM
CJ MEDEVAC
  • 11,000 POSTS
Can you send a pretty pic of the area where you are hearing this evil audio and post it on here?
Gotta throw this out there too!
You know
Jeep
Wrote the book on four wheel drive
Ever considered being assimilated over to our side?
Just something to consider
My two are 40 and 70 years young
They love me, as I do them!
Better send your expedition pics before I convince you to walk into the light!
The Medic
Aug 28, 2016 at 1:55 AM
